Normal Topic Applet Error (Read 4516 times)
Freizeitsoldat
Applet Error
Oct 7th, 2009 at 7:13am
iīm trying out the JDiag-Demo Version and i often get Java Errors, so that i can not access (and use) the Applet.
With java jre 1.5. the applet is not loading at all.
When i use jre 1.6. on a german Win XP the applet is loading but:
if i set a shape node like node.setText(blablabla) i can do it. The next order like node.setHyperlink(blablabla) generates an error.
On my laptop with an english XP i can use the applet in my firefox and iexplorer. But i get the same error with opera ( second order is not working).
The Java console tells me, that i have not enough rights to execute node.setHyperlink, but i canīt get it. I have the rights for one order, but not for two??? Itīs funny, but i would like to know how to fix it before i buy the code package.
Thank you for your help in advance,
Alex
Re: Applet Error
Reply #1 - Oct 7th, 2009 at 10:20am
Change setHyperlink to setHyperLink and it should work - note the L character case. Do you mean JRE 1.5 on German XP cannot load the applet but 1.5 on English XP loads it fine?
Freizeitsoldat
Re: Applet Error
Reply #2 - Oct 7th, 2009 at 10:43am
Hello Stoyo,
no in Jre 1.5 it doesnīt work at all. The Hyperlink sugestion is working.
Now i donīt have any failures in 1.6. in Firefox and in the Internet Explorer anymore.
But i still can not open the applet in jre 1.5. Also i can not use Applet objects in Opera because of security reasons as you can see in the code below:
java.security.PrivilegedActionException: java.lang.reflect.InvocationTargetException
at java.security.AccessController.doPrivileged(Native Method)
at com.opera.PrivilegedThread.run(LiveConnectPrivilegedActions.java:290)
at java.lang.Thread.run(Unknown Source)
I mention that the error occures because of the strict security policy in Opera. Do you have some experience with opera?
Thank you
Alex
Re: Applet Error
Reply #3 - Oct 7th, 2009 at 10:50am
Hi Alex,
It works fine in my Opera version 9. Are you on Opera 10 now?
Re: Applet Error
Reply #4 - Oct 7th, 2009 at 10:59am
Also our online demo seems to work on Java 1.5:
http://mindfusion.eu/demos/jdiagram/start.htm
My Java console says Using JRE version 1.5.0_11-b03 Java HotSpot(TM) Client VM when the demo loads and Java 1.6 is disabled from the Java control panel.
Freizeitsoldat
Re: Applet Error
Reply #5 - Oct 7th, 2009 at 11:08am
yes i use Opera 10.
I donīt know why itīs not working in 1.5. Itīs really strange.
Alex
Re: Applet Error
Reply #6 - Oct 7th, 2009 at 11:27am
For JRE 1.5, what's the exact version you have - update number and all? I'll try this with Opera 10 in a minute.
Re: Applet Error
Reply #7 - Oct 7th, 2009 at 11:39am
Opera 10 worked for me, freshly installed and with all default settings -
Could you check if this page loads on your system -
Freizeitsoldat
Re: Applet Error
Reply #8 - Oct 7th, 2009 at 12:43pm
in Opera the Applet loads, but if i try to get objects in javascript (like var app = applet.getDiagram(); etc etc.) it fails in Opera. I think itīs because of the security policy of opera. (In firefox, chrome, iexp it works fine).
I think itīs not a JDiagram problem, but an Security issue. If you have some idea how to allow Opera to use diagram.saveToSting(). e.g., please tell me. Otherwise thank you for your help - i will buy the code even if Opera is not working Smiley
Alex
Re: Applet Error
Reply #9 - Oct 7th, 2009 at 12:49pm
Opera displays some "click to activate and use this control" prompt. Have you tried accessing the API after this click activation? If it works then, I'll send you a script we used a few years ago when IE required such activation too; it might also work for Opera.
