Normal Topic unable to remove node - Factory.CreateShapeNode (Read 1462 times)
meriturva
Oct 14th, 2009 at 10:28am
Diagram Wpf version 2.2.1 (trial)
Behaviour : DrawControls
if i create a new node just dragging a rectangle on the diagram area, the node is created correctly and it is possible to remove it just selecting and pressing del key.
if i use the factory with the code:
this.diagram.Factory.CreateShapeNode(diagramPoint.X - offsetPoint.X, diagramPoint.Y - offsetPoint.Y, 220, 220);
the node is selectable but it is not possible to delete it.
any ideas?
Re: unable to remove node - Factory.CreateShapeNod
Reply #1 - Oct 14th, 2009 at 11:09am
I suppose the keyboard focus is not on the Diagram control. If it's inside a ScrollViewer, set <ScrollViewer Focusable="False" ... >, otherwise the ScrollViewer might steal the focus.
meriturva
Reply #2 - Oct 14th, 2009 at 12:12pm
Perfect! The ScrollViewer was the problem!
Thanks.
