Very Hot Topic (More than 25 Replies) Dragging links (Read 17870 times)
Hunter
Dragging links
Dec 28th, 2009 at 1:28pm
Can I drag the link by mouse when cursor is in the middle of control points? For example I want to add some control points when user presses the left button and I want to allow him drag the link between these control points. I use this code
	  /// <summary>
	  /// Occurs when mouse pointer is over the link and left button is down
	  /// </summary>
	  /// <param name="sender">Sender object</param>
	  /// <param name="e">Provides arguments for this event</param>
	  private void OnLinkMouseLeftButtonDown(object sender, MouseEventArgs e)
		DiagramLink link = sender as DiagramLink;
		Point mousePos = e.MouseDevice.GetPosition(m_Diagram);
		//foreach(Point ctrlPnt in link.ControlPoints)
		for (int i = 0; i < link.ControlPoints.Count; ++i)
		    Point ctrlPnt = link.ControlPoints[i];
		    if (Math.Abs(mousePos.X - ctrlPnt.X) < 0.5)
			  Point nextCtrlPnt = link.ControlPoints[i + 1];
			  Point newPnt = new Point();
			  newPnt.X = ctrlPnt.X;
			  Point nextNewPnt = new Point();
			  nextNewPnt.X = ctrlPnt.X;
			  if (ctrlPnt.Y < nextCtrlPnt.Y)
				newPnt.Y = ctrlPnt.Y + 15;
				nextNewPnt.Y = nextCtrlPnt.Y - 15;
				link.ControlPoints.Insert(i + 1, newPnt);
				link.ControlPoints.Insert(i + 2, nextNewPnt);
			  else
				newPnt.Y = ctrlPnt.Y - 15;
				nextNewPnt.Y = nextCtrlPnt.Y + 15;
				link.ControlPoints.Insert(i + 2, newPnt);
				link.ControlPoints.Insert(i + 1, nextNewPnt);
			  link.UpdateFromPoints(false, false);
			  break;
		    else if (Math.Abs(mousePos.Y - ctrlPnt.Y) < 0.5)
			  //To do: Add horisontal segment
But now link drags only when cursor is over one of control points.
Re: Dragging links
Reply #1 - Dec 28th, 2009 at 1:53pm
There's a built-in feature that does something similar. Check if diagram.AllowSplitLinks = true works for you.
Hunter
Re: Dragging links
Reply #2 - Dec 28th, 2009 at 2:08pm
Yes. It works similiar as I need. Thank you very much
Hunter
Re: Dragging links
Reply #3 - Dec 29th, 2009 at 8:54am
I have a question. After I convince my technical director to buy your library could I reckon that you will add the behavior of dragging links as in the Matlab->Simulink?
Re: Dragging links
Reply #4 - Dec 29th, 2009 at 11:15am
In what manner are links dragged in Matlab->Simulink? It is possible to customize much of the drawing behavior using a custom BehaviorBase -derived class and possibly a derived DiagramLink.
Hunter
Re: Dragging links
Reply #5 - Dec 30th, 2009 at 10:50am
Are there any examples, exclude example in help file, how to implement  public override CursorHint SetMouseCursor(Point point, out bool startInteraction)?
Re: Dragging links
Reply #6 - Dec 30th, 2009 at 1:52pm
This method should do some hit-testing and return which of the diagram's Cursor properties to set as the current cursor. What exactly are you trying to achieve? You might also check the Diagram.OverrideCursor property - it will display your custom cursor until you set it back to null.
Hunter
Re: Dragging links
Reply #7 - Dec 30th, 2009 at 3:48pm
I want to override behavior of dragging links. When I drag a link and mouse is over the link (not over cotrol point) I want that if right-side control can't move then add the control point left and move link. The same according to left-side control point. If it can't be moved the control point must be add left and link link must be moved. To describe this behavior by words is too hard for me. Easier to demonstrate it on Virtual machine example with another software or on video clip
Re: Dragging links
Reply #8 - Dec 31st, 2009 at 10:45am
Do you need something similar to the AllowSplitLinks behavior, but want to specify yourself where the new control point should be inserted? In such case you can override StartDraw to return new InteractionState(link, segmentToSplit, Action.Split). This will insert the new point so that it divides the specified segment into two new segments.
Otherwise, please send us a link or a video file that shows your requirement to support@mindfusion.eu.
Hunter
Re: Dragging links
Reply #9 - Jan 4th, 2010 at 8:12am
Yes, I need something similiar to the AllowSplitLinks behavior. I try to do it without your assistance but I need to know how to override StartDraw for change only links processing behavior and node processing behavior stay as is. Can you show me an example of StartDraw function for any standard behavior? It will be great to see StartDraw for Behavior.DrawLinks
Hunter
Re: Dragging links
Reply #10 - Jan 4th, 2010 at 9:34am
I sent you the e-mail with avi-files and some comments in the letter
Re: Dragging links
Reply #11 - Jan 4th, 2010 at 12:45pm
Try diagram.CustomBehavior set to an instance of this class:
http://mindfusion.eu/_samples/MyBehavior2.cs
It might be better to implement the horizontal/vertical segment moving code in UpdateModify override of DiagramLink instead of simulating the mouse moving only vertically/horizontally, but it's easier to inherit from the Behavior class than from diagrmaLink.
This code implements split only for the horizontal segments case and does not check on which side of nodes the segment lies (it will work only for left to right links). You will need to add some checks in the first two if blocks to add new points at the correct offset.
Hunter
Re: Dragging links
Reply #12 - Jan 4th, 2010 at 1:48pm
Thank you very much! This code is very helpful for me and I try to modify it for implement all features which I need. Now I have one question: after I change
m_Diagram.Behavior = Behavior.DrawLinks;
to
m_Diagram.Behavior = Behavior.Custom;
m_Diagram.CustomBehavior = new LinkBehavior(m_Diagram);
when I try to select the group of nodes and links by mouse it draws me the rounded rectangle. Where I can fix this?
Is it correct to change
return base.StartDraw(point);
on
            var node = Diagram.GetNodeAt(point);
            if (node == null)
                return new InteractionState(Diagram.Selection, 0, Action.Create);
Re: Dragging links
Reply #13 - Jan 4th, 2010 at 2:11pm
If you were using the standard DrawLinks behavior, derive the custom class from DrawLinksBehavior instead of LinkShapesBehavior to be as close as possible to the previous results. Otherwise - yes, you should be able to start drawing the selection rectangle like that...
Hunter
Re: Dragging links
Reply #14 - Jan 4th, 2010 at 2:23pm
Thanks a lot!
