Normal Topic Can I put Anchor Points on Diagram Links? (Read 1236 times)
solisgsandc
Jan 14th, 2010 at 8:24pm
Is it possible to have anchor points inside the diagram links?
I am thinking if there is something prebuilt already that I just turn on some property in the DiagramLink.
Re: Can I put Anchor Points on Diagram Links?
Reply #1 - Jan 14th, 2010 at 8:55pm
You can't connect a link directly to another link, if that's what you are asking. You might try using the AttachTo method to attach small nodes to links to serve as their anchor points.
