Normal Topic TimetableSettings.ShowNavigationButtons (Read 3208 times)
springy
Jan 25th, 2010 at 1:09pm
I can't see any buttons when enabling this. Is there a second property which has to be set for this to working?
I tried MinColumnSize and MinItemSize but still all dates are shown at once.
/\/\arkus.
Re: TimetableSettings.ShowNavigationButtons
Reply #1 - Jan 25th, 2010 at 2:22pm
This property is still not functional and was not intended to be visible in this release. We will try to enable the property for the next build. If not, we will remove the property from the public API.
Thank you for all your feedback.
springy
Reply #2 - Jan 28th, 2010 at 4:53pm
Since it works now I realized that it does something different than I thought it would Wink
The perfect behavior (for me, currently) would be if I could say "display max. 3 days at once side by side" and "only scroll/navigate through the days defined in TimetableSettings.Dates".
Currently TimetableSettings.Dates controls the initial state but then you can navigate away unlimitedly.
/\/\arkus.
Reply #3 - Jan 29th, 2010 at 7:31am
The only way you can currently influence the behavior of the navigation buttons is through the TimetableSettings.ScrollStep property.
If its necessary we can add an event that is raised when the buttons are clicked. Otherwise, you can use your own buttons with custom logic.
