Normal Topic Dragging Nodes (Read 2167 times)
Freizeitsoldat
Dragging Nodes
Feb 8th, 2010 at 2:35pm
is there any event raised when i´m dragging a node in my flowchart?
I need information about the node beyond the dragged node and i need the relative position. (My goal is to sort swimlanes. If i drag a swimlane more than 50% over another lane there should be a new order of the given swimlanes)
Thank you,
Alex
Re: Dragging Nodes
Reply #1 - Feb 8th, 2010 at 2:42pm
Try doing that from the nodeModified or nodeModifying handler.
Freizeitsoldat
Re: Dragging Nodes
Reply #2 - Feb 8th, 2010 at 3:09pm
Thank you,
but which method can i use to get the node where my modifyied node is dragged over? (Like node.getNodeDraggedOver...() )
Alex
Re: Dragging Nodes
Reply #3 - Feb 8th, 2010 at 3:23pm
You can use the getNodeAt overload that takes an "excludeSelected" parameter, so that getNodeAt ignores the dragged node while traversing the Z order.
