Normal Topic LinkCreated undo/redo (Read 4185 times)
hhko
Feb 22nd, 2010 at 9:57am
Hi.  Grin
when LinkCreated, I changed origin shape of brush.
and I called UndoManager.Undo();
but. undo only created link.
why? Does not restore the shape of brush?
private void DiagramLinkCreatedEvent(object sender, MindFusion.Diagramming.LinkEventArgs e)
     // I changed Origin of Brush
     // so, I want to undo created Link and origin of Brush.
     e.Link.Origin.Brush = new MindFusion.Drawing.LinearGradientBrush(Color.FromArgb(100, Color.White), Color.FromArgb(212, 212, 90), 270);
Re: LinkCreated undo/redo
Reply #1 - Feb 22nd, 2010 at 10:44am
hhko
Reply #2 - Feb 22nd, 2010 at 11:14am
Hi. thank you.
I want to composite ChangeItemCmd(change brush) and AddItemCmd(Link).
but. currently, divided two commands.
how to implement one command ?
Reply #3 - Feb 22nd, 2010 at 11:58am
I think the brush will be saved as part of the add command if you change it in response to the InitializeLink event. Or otherwise you could use the MergeUndoRecords method to combine the last two commands.
hhko
Reply #4 - Feb 22nd, 2010 at 3:57pm
LinkCreated event is succeed.
    MindFusion.Diagramming.Commands.ChangeItemCmd cmd = new MindFusion.Diagramming.Commands.ChangeItemCmd(e.Link.Origin, "Change");
    ChangeFactorColor(e.Link.Origin);
    cmd.Execute();
    diagramView.Diagram.UndoManager.History.MergeUndoRecords(2, "ChangeFactorColor");
but. When a shape is deleted, LinkDeletedEvent is failed(MergeUndoRecords function is an exception).
private void DiagramLinkDeletedEvent(object sender, LinkEventArgs e)
    try
	  cmd.Execute();
    catch (System.Exception ex)
How to improve code?
Reply #5 - Feb 23rd, 2010 at 9:20am
What does the ChangeFactorColor method do? I've tried setting a property in its place, but there wasn't any exception thrown.
hhko
Reply #6 - Feb 23rd, 2010 at 10:07am
void ChangeFactorColor(DiagramItem item)
    item.Brush = new MindFusion.Drawing.LinearGradientBrush(Color.FromArgb(100, Color.White), Color.FromArgb(212, 212, 90), 270);
MergeUndoRecords function is exception.
exception is System.NullReferenceException.
hhko
Reply #7 - Feb 23rd, 2010 at 10:13am
LinkCreated event is called from execute function of AddItemCmd is completed.
so. this code can succeed.
MindFusion.Diagramming.Commands.ChangeItemCmd cmd = new MindFusion.Diagramming.Commands.ChangeItemCmd(startShape, "Change");
startShape.Brush = ...;
cmd.Execute();
but. I think that LinkDeleted event is not called from execute function of RemoveItemCmd is completed.
MergeUndoRecords(2 <-- i think this is bug?
how to improve ?
hhko
Reply #8 - Feb 23rd, 2010 at 11:26am
I sended example source code and avi movie to your e-mail.
please check.  Wink
Reply #9 - Feb 23rd, 2010 at 3:47pm
It seems MergeUndo cannot be executed in the context of an active composite command, and the control is recording one when deleting items. It works fine if you leave only this code:
ChangeItemCmd cmd = new ChangeItemCmd(e.Link.Origin, "Change");
e.Link.Origin.Brush = new MindFusion.Drawing.LinearGradientBrush(Color.FromArgb(100, Color.White), Color.Blue, 270);
cmd.Execute();
and there's no need to merge records because the ChangeItem command becomes a part of the composite command anyway.
