Normal Topic Issue with createing shapenode in second container (Read 1032 times)
rajesh_patil74
Mar 9th, 2010 at 8:16am
Hi Stoyo
With following code, allows me select container item, which is added in another container ....
ContainerNode container = new ContainerNode(this.diagram);
container.Bounds = new Rect(0, 0, 500, 500);
this.diagram.Nodes.Add(container);
ShapeNode shape1 = new ShapeNode(this.diagram);
shape1.Bounds = new Rect(0, 0, 50, 50);
shape1.Constraints.KeepInsideParent = true;
container.Children.Add(shape1);
this.diagram.Nodes.Add(shape1);
ContainerNode container2 = new ContainerNode(this.diagram);
container2.Bounds = new Rect(0, 0, 200, 200);
container2.Constraints.KeepInsideParent = true;
container.Children.Add(container2);
this.diagram.Nodes.Add(container2);
Now, if I add following new shape in "container2" doesn't allow me to select container2. It gets placed below container1. [ Container 1 and container2 gets same Z-Index i.e "0".
shape1.Bounds = new Rect(25, 25, 50, 50);
container2.Children.Add(shape1);
Will you help me in fixing this issue.
Re: Issue with createing shapenode in second conta
Reply #1 - Mar 9th, 2010 at 11:14am
This works:
The container's ZIndex is automatically set to a lower value than the one of the added item. However the item's index is considered 0 before adding it to diagram.Items, so you must only exchange the positions of the container.Children.Add and diagram.Nodes.Add calls.
