Normal Topic Missing VisioExport.vxt (Read 4608 times)
choohj70
Apr 12th, 2010 at 1:02pm
I am trying to export a diagram to vsd. But when i try I am getting an error due to missing VisioExport.vxt.
I cannot seem to find it anywhere. Can you please send me a copy of VisioExport.vxt?
Thank you.
James
Re: Missing VisioExport.vxt
Reply #1 - Apr 12th, 2010 at 1:48pm
It should be in the "Program files\Diagramming for ASP.NET\Redistributable" folder.
choohj70
Reply #2 - Apr 12th, 2010 at 4:13pm
Stoyan,
These are the only files in the directory.
/ImageGen.CS
/ImageGen.VB
ClientDiagramApp.xap
JDiagram.jar
Am I using an incomplete version?
Thanks.
choohj70
Reply #3 - Apr 12th, 2010 at 4:14pm
BTW, the folder structure that I have is
C:\Program Files\MindFusion\MindFusion.Diagramming for ASP.NET\Redistributable
Thank you.
Reply #4 - Apr 12th, 2010 at 5:35pm
Could you try it with the V3.1 installer from http://www.clientsarea.eu/ ?
choohj70
Reply #5 - Apr 12th, 2010 at 5:43pm
I will try that. Just created an account in the client area and is waiting for confirmation from the administrator.
Thanks.
choohj70
Reply #6 - Apr 12th, 2010 at 7:14pm
The error says "Could not find file 'C:\Program Files\Microsoft Visual Studio 8\Common7\IDE\VisioExport.vxt'."
Does it have to be in that folder or is there a way to specify a different folder?
Thank you.
Reply #7 - Apr 12th, 2010 at 7:43pm
Set the exporter's TemplatePath property to the full path to the template (e.g. returned by Server.MapPath).
choohj70
Reply #8 - Apr 13th, 2010 at 2:36am
This has been resolved. Thank you.
