Normal Topic Selected Node Movement by Directional Keys (Read 1458 times)
khurramdbg
Apr 16th, 2010 at 5:37am
Hi All,
I need the selected nodes on my diagram to move by pressing the directional keys on the keyboard.
The movement should be in sync of the directional key pressed.
Can someone please tell me how to do that
Re: Selected Node Movement by Directional Keys
Reply #1 - Apr 16th, 2010 at 12:14pm
Set KeyDownScript="onKeyDown" for the DiagramView, and add a handler that checks the KeyCode argument:
function onKeyDown(sender, args)
	if (args.getKeyCode() == 37)
		// move left
The codes for left, up, right and down keys are 37, 38, 39 and 40 respectively. Moving selected nodes can be done by calling their getBounds() method, adding some offset to the coordinates of the returned rectangle and passing the modifiect rect to setBounds.
