Hot Topic (More than 10 Replies) Zooming twice using ZoomToRect creates probem (Read 6620 times)
kaykay15
Apr 16th, 2010 at 11:11am
Hello Team,
I have implemented zoomtorectangle functionaly and it's working fine when i zoom it for the first time... but when i zoom it second time, it is not working as expected.
for the first time the zoomfactor is 100% and when we zoom it to the selected rectangle then the zoomfactor changes, i think the zoomtorect is not working when the zoomfactor not equal to 100%.
Is this an known issue, are there any workarounds for this?
-KayKay
Thanks,&&-KayKay
Re: Zooming twice using ZoomToRect creates probem
Reply #1 - Apr 18th, 2010 at 6:52am
This seems to work fine regardless of the current ZoomFactor:
private void Diagram_NodeDoubleClicked(object sender, MindFusion.Diagramming.Silverlight.NodeEventArgs e)
	diagram.ZoomToRect(e.Node.Bounds);
What kind of coordinates are you setting for the zoom rectangle?
kaykay15
Reply #2 - Apr 23rd, 2010 at 6:15am
Hey that works fine in many of the cases but some times it fails, if the selection rectangle height is far more greater than the width..
the selected area is not in the view completely, how do i overcome this issue.
And also i am not able to find  diagram.BringIntoView() method for diagram!
-Kranthi
Thanks,&&-KayKay
kaykay15
Reply #3 - Apr 23rd, 2010 at 9:39am
This is the code i am using,
[code]
ContainerNode selectedRectangle = activityDiagram.Items[activityDiagram.Items.Count - 1] as ContainerNode;
if (selectedRectangle != null)
     activityDiagram.ZoomToRect(selectedRectangle.Bounds);
     //Removes the selection rectangle drawn by the user to select the zoom area
    activityDiagram.Items.Remove(selectedRectangle);
[/code]
in the above code selectedRectangle is the node drawn by the user to zoom into.
When the selected rectangle is large, zoomtorect is working as expected. and when teh selected rectangle bounds are small(equal to the node bounds) it is failing to zoom into the selected region
Thanks,&&-KayKay
Reply #4 - Apr 23rd, 2010 at 3:14pm
It works fine for me.  What are your current ZoomFactor and rect.Bounds when it doesn't?
kaykay15
Reply #5 - Apr 26th, 2010 at 10:23am
Hello Stoyon,
There are many cases when the zoomtorect fails, below are the bounds and zoom factor at which it fails regularly.
Diagram bounds: {0,38,2580,851}
Selected Rectangle bounds: {849,750,154,98}
Diagram ZoomFactor : 100
How do we make the selected area to be centered in the view, i found in some fourm posts there is some method like BringIntoView(), is this still available. i am not able to find this method for the diagram control.
Thanks,&&-KayKay
Reply #6 - Apr 26th, 2010 at 12:41pm
The only problem I can see is that the border of the node used as a zoom tool is hidden behind the scrollbar. This might also depend on the client area size though; what are your ActualWidth and ActualHeight for the parent scroll viewer?
kaykay15
Reply #7 - Apr 30th, 2010 at 6:17am
Hello Stoyon,
I've sent you an IM regarding steps to reproduce my issue.
This issue is not only reproducible zooming twice but it is also behaving same on zooming first time.
Please checkout the IM.
As this issue is a high priority one for us.
-KayKay
Thanks,&&-KayKay
Reply #8 - Apr 30th, 2010 at 7:52am
Yes, I can see this in your app but cannot get it to happen in my test project. You'll have to send us a sample project that reproduces this for our developer to check what happens.
kaykay15
Reply #9 - May 3rd, 2010 at 11:16am
Hi Stoyo,
We have really customized our application a lot and will take much time to make a sample project which can reproduce our problem.
can you please send me your sample code so that i can verify where i am doing wrong in my code.
Thanks,&&-KayKay
Reply #10 - May 3rd, 2010 at 12:21pm
You can find my test project here:
https://mindfusion.eu/_temp/DiagliteTester.zip
Draw some nodes and then hit the "Zoom test" button at the top. Now draw around existing nodes to call diagram.ZoomToRect(e.Node.Bounds) - this works fine for me regardless of where the nodes are located.
kaykay15
Reply #11 - May 3rd, 2010 at 12:52pm
I've updated one of the samples provided by Mindfusion documentation to reproduce my problem.
Here you can find the http://docs.google.com/leaf?id=0B6zEK6RhNaOZMzUwOTI0NzctODUxMC00NmFiLTg0ZDktOWEx... updated code.
Steps to reproduce:
-> Run the applicaiton
-> Default diagram will be generated, now click on ZoomToRectangle Button provided
-> Draw a rectangle to create an area to zoom in
-> On Diagram MouseLeftButtonUp i have written code to zoom into the selected region
In this case it is not even zooming once to the selected region. Please have a look at this,
In the meanwhile i will look into the sample code provided by you.
Thanks,&&-KayKay
Reply #12 - May 3rd, 2010 at 2:03pm
I suppose it doesn't work in that sample because there's no a ScrollViewer. ZoomToRect requires a ScrollViewer in order to set the scroll position.
kaykay15
Reply #13 - May 5th, 2010 at 11:29am
Hello Stoyon,
Thanks for all your effort from your side... At last my issue has been fixed, problem was with our code...Sad.
If you observe in our application there is a zoomslider at the bottom right corner, which is causing the problem.
when we select regional zoom it was setting the slider value and our max slider value was 200, Once the slider value was set again the diagram zoomfactor was setting, resulting in a two way binding...
Once again.. thanks a lot for all your effort..
Thanks,&&-KayKay
Reply #14 - May 5th, 2010 at 12:35pm
Great to hear that. We'll release the new version then in a couple of hours, also containing the fix for the link crossings at segment ends you needed.
