Normal Topic How to control Link connectivity/route (Read 3703 times)
kaykay15
Apr 22nd, 2010 at 11:14am
How does Mindfusion determine the path that a connector takes while connecting two shapes. We are trying to draw some diagrams with DiagramLink properties Style=Cascading, AutoRoute=true. The paths that get drawn at times are not optimal as they should be. See the link for image for more details
http://docs.google.com/leaf?id=0B4xAPIW5oeouMjQwNjRkYjYtMWIzYi00Njg4LWFmMGUtNmZi...
Is there any way we can control the diagram link connectivity algorithm to achieve the correct layout.
-KayKay
Thanks,&&-KayKay
Re: How to control Link connectivity/route
Reply #1 - Apr 22nd, 2010 at 11:23am
Try setting a larger RoutingOptions.TurnCost if you are using GridRouter, or set larger QuickRouter.TurnCost otherwise.
praveenbattula
Reply #2 - Apr 22nd, 2010 at 2:02pm
How to use RoutingOptions? It's a class and for the diagram this property is read only. I mean only get not set. So, can you please explain a bit?
thanks
Reply #3 - Apr 22nd, 2010 at 2:23pm
Set diagram.RoutingOptions.TurnCost = ...
praveenbattula
Reply #4 - Apr 22nd, 2010 at 3:15pm
Hi Stoyo,
I have tried all the options available and found no change.
Is this right?
diagram.RoutingOptions.TurnCost = RoutingOptions.TurnCost;
thanks
Reply #5 - Apr 22nd, 2010 at 3:18pm
Try diagram.RoutingOptions.TurnCost *= 2; This will affect only GridRouter.
If you are using the default QuickRouter, set (diagram.LinkRouter as QuickRouter).TurnCost = ...
praveenbattula
Reply #6 - Apr 23rd, 2010 at 3:13am
Stoyo,
I appreciate the help. But, some how the changes are not applying in my case. I am trying everything, but no use. The diagram not coming as expected. There are two nodes which are close by, but it is drawing in long path. Actually they are in the same vertical line, it is not connecting directly, it is taking complex route and connecting them. I am not having any idea on how to resolve this.
Are there any other options I can try with?
thanks
Reply #7 - Apr 23rd, 2010 at 6:16am
Please email the diagram xml to support@mindfusion.eu.
praveenbattula
Reply #8 - Apr 23rd, 2010 at 6:57am
Sorry Stoyo,
It was my mistake. After I set LinkRouter of diagram to GridRouter the link connected fine.
Thanks a lot.
-Praveen
