Normal Topic No Unicode support for text display on bubble? (Read 2626 times)
James Edwards
May 23rd, 2010 at 3:50pm
Hi Stoyo,
I'm using the Mindfusion.Diagramming component in ImageMap mode.
Whenever I use japanese or chinese characters in the Text property of a shape,  it shows up as squares.
Is Unicode supported? How do I enable it on the diagram?
Appreciate your soonest response.
Re: No Unicode support for text display on bubble?
Reply #1 - May 23rd, 2010 at 4:02pm
Hi James,
Try setting the Font property to a Unicode font, e.g. "Arial Unicode MS". You could also disable the StringFormatFlags.NoFontFallback flag in TextFormat.FormatFlags, and then "Arial" should automatically fall back to "Arial Unicode MS".
James Edwards
Reply #2 - May 23rd, 2010 at 4:35pm
It works! Thanks stoyan
