Normal Topic DiagramView to partition big drawing (Read 1076 times)
solisgsandc
Jun 10th, 2010 at 8:03pm
Is this a strategy that I can use to partition my big drawing with 7,000 plus controls.
When was this feature introduced in WPF.
Re: DiagramView to partition big drawing
Reply #1 - Jun 11th, 2010 at 7:24am
DiagramView is available since the 2.1.1 release. You can use it to show different parts of a big diagram, e.g. by implementing a split-view feature or MDI interface. All your 7000 controls will be part of the same WPF visual tree though; if you need to partition it into smaller parts, you will have to use several Diagram objects.
