Normal Topic TimeTableSettings 24 hour cells not rendering (Read 3816 times)
Jos
Jun 25th, 2010 at 2:18pm
Im trying a TimeTable view to work with 24 hour cells, but I'm experiencing stange things. I suspect a bug. If you run the code below you will find that the cells don't render.
If you change the CellTime to anything less then 24 hours everything works just fine.
this.Calendar.CurrentView = MindFusion.Scheduling.Silverlight.CalendarView.Timetable;
this.Calendar.TimetableSettings.HeaderDateFormat = "MMMM yyyy";
this.Calendar.TimetableSettings.Dates.Clear();
this.Calendar.TimetableSettings.Dates.Add(this.Calendar.Date);
this.Calendar.TimetableSettings.StartTime = 0;
// This line causes the cells not to render. Any value lower than 24 hours does work.
this.Calendar.TimetableSettings.CellTime = new TimeSpan(24, 0, 0);
this.Calendar.TimetableSettings.EndTime = 44640;
this.Calendar.TimetableSettings.GeneralFormat = "dd MMMM";
this.Calendar.TimetableSettings.CellSize = 100;
this.Calendar.TimetableSettings.TimelineSize = 100;
Grtz Jos
Re: TimeTableSettings 24 hour cells not rendering
Reply #1 - Jun 25th, 2010 at 2:55pm
We will have a look at this. However, keep in mind that the Timetable view has been designed to work with up to 48-hour column intervals so I cannot guarantee that we will be able to make it work on such a big scale.
I will let you know when I have something ready.
Jos
Reply #2 - Jun 28th, 2010 at 6:45am
Thanks for the quick reply. If you want I can sent you my test project.
Kind regards
Jos ter Doest
WiZZiX
Reply #3 - Jun 28th, 2010 at 11:45am
A new preliminary version of MindFusion.Scheduling for Silverlight can be downloaded from the following link:
https://mindfusion.eu/_pln_trial/MindFusion.Scheduling.Silverlight.2.1.1b.zip
The version enables 24-hour cells in Timetable view. However, this is considered not officially supported, hasn't been fully tested and might not work with all of the applicable settings. Please, try it out and let me know if you have any problems.
Jos
Reply #4 - Jun 29th, 2010 at 8:39am
Thanx,
I will test this asap. For our release we will wait for your next official release.
Kind regards
Jos ter Doest
WiZZiX
