Normal Topic Arrange algorithm similar to stackpanel (Read 1218 times)
rajesh_patil74
Aug 2nd, 2010 at 10:28am
Hi Stoyo
Can you help me is creating my own layouts arrangement for diagram controls -
For eq. I have a container node which contains all child items. I need to arrange them horizontal and vertically with fixed number of nodes in each row.
Is it possible to integrate this type of layout arrangement in mind fusion libarary.
P.S
I think layeredLayout is doing the same thing. Is it possible to specify number of nodes in each row and then it automatically split the layer in another row. ?
-Rajesh
Re: Arrange algorithm similar to stackpanel
Reply #1 - Aug 2nd, 2010 at 11:40am
Hi Rajesh,
Do you mean something like this?
void ArrangeInRows(ContainerNode container, int nodesPerRow)
	double currX = container.Bounds.Left;
	double currY = container.Bounds.Top;
	double rowHeight = 0;
	int n = 0;
	foreach (var node in container.Children)
		var r = node.Bounds;
		r.X = currX;
		r.Y = currY;
		node.Bounds = r;
		rowHeight = Math.Max(rowHeight, node.Bounds.Height);
		currX = r.Right;
		if (++n == nodesPerRow)
			n = 0;
			currY += rowHeight;
			rowHeight = 0;
