Normal Topic Can we navigate through Nodes using "Tab" (Read 1711 times)
venki5star
Aug 5th, 2010 at 9:11am
You know well about TabIndex property of a control. Do WPF Diagram nodes has similar property?
How can I achieve it?
Castle Rider
Re: Can we navigate through Nodes using "Tab&
Reply #1 - Aug 5th, 2010 at 10:16am
They don't. You might define yours as attached property and then implement tabbing as shown below.
diagram.CommandBindings.Add(
	new CommandBinding(EditingCommands.TabForward, OnTabForward));
diagram.InputBindings.Add(
	new InputBinding(EditingCommands.TabForward, new KeyGesture(Key.Tab)));
private void OnTabForward(object sender, ExecutedRoutedEventArgs e)
	int numNodes = diagram.Nodes.Count;
	if (numNodes == 0)
		return;
	var currentNode = diagram.ActiveItem as DiagramNode;
	if (currentNode == null)
		diagram.ActiveItem = diagram.Nodes[0];
		return;
	int next = (diagram.Nodes.IndexOf(currentNode) + 1) % numNodes;
	diagram.Selection.Change(diagram.Nodes[next]);
venki5star
Reply #2 - Aug 5th, 2010 at 12:20pm
Thanks. Lemme try it and get back to you.
Castle Rider
