Normal Topic CreateArrow, CreateBox, CreateTable (Read 1084 times)
ogre
Aug 11th, 2010 at 4:03pm
in the past i work with the Class Libraries FlowChart.NET (v4.3.1.16858 ). There was functions like: CreateArrow, CreateBox and CreateTable. Now i try to work with the new Version FlowChart.NET version 5.3.5 there are not them any more. The manuel ist quit good to change older versions into newer versions, but i can't find somethig about this functions.
What are the name of this functions in the new version?
thx ogre
Re: CreateArrow, CreateBox, CreateTable
Reply #1 - Aug 11th, 2010 at 4:08pm
There are equivalent methods provided by the Diagram.Factory object, e.g.
var node = diagram.Factory.CreateShapeNode(...);
or you might add an item to the respective collection:
var node = new ShapeNode(...);
diagram.Nodes.Add(node);
