Normal Topic When I draw a NOde , this exception comes out. (Read 1620 times)
gamjaradio
Aug 23rd, 2010 at 7:55am
Exception in thread "AWT-EventQueue-0" java.util.NoSuchElementException
at java.util.AbstractList$Itr.next(Unknown Source)
at com.mindfusion.diagramming.Diagram.b(Unknown Source)
at com.mindfusion.diagramming.Diagram.a(Unknown Source)
at com.mindfusion.diagramming.DiagramView.a(Unknown Source)
at com.mindfusion.diagramming.DiagramView.paintComponent(Unknown Source)
at javax.swing.JComponent.paint(Unknown Source)
at javax.swing.JComponent.paintToOffscreen(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
at javax.swing.RepaintManager.paint(Unknown Source)
at javax.swing.JComponent._paintImmediately(Unknown Source)
at javax.swing.JComponent.paintImmediately(Unknown Source)
at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
at javax.swing.RepaintManager.seqPaintDirtyRegions(Unknown Source)
at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Re: When I draw a NOde , this exception comes out.
Reply #1 - Aug 23rd, 2010 at 8:14am
It looks like thread synchronization issue, an item disappearing from the collection while it's being iterated. The control is not thread safe, and if you need to modify the diagram outside of the Swing UI thread, use SwingUtilities.invokeAndWat to do that.
