Normal Topic Validate all ZIndex (Read 1650 times)
yrauma
Validate all ZIndex
Dec 1st, 2010 at 3:29pm
Hello Stoyan.
I improved a lot mu rearranged with embeded containers.
One of my last issue are the ZIndex. Often after a rearrage, my containers are not visible because they are drawn behind the container that content it.
Is there a way to reset all Z for the whole diagram ? like an algo that pass through all nodes and set the ZIndex to the correct value ? or should I do it myself ?
Re: Validate all ZIndex
Reply #1 - Dec 1st, 2010 at 4:22pm
Hello Amaury,
The layout classes do not change ZIndex. Are you perhaps removing and adding containers during the recursive calls? Anyway if you call container.ZBottom() for the currently arranged container before returning from the recursive method, the Z order should be ok. Thus any child containers would be brought to the back before their parent container is, and so they should appear above it once the outermost method exits.
yrauma
Reply #2 - Dec 1st, 2010 at 6:35pm
One more time,
thanks again Stoyan.
Works perfectly. I dont know the Z changed, I dont do anyhing regarding that in my code.
