Normal Topic Visual Studio 2010 .net target 3.5 (Read 3308 times)
isilva
Dec 13th, 2010 at 3:34pm
My application project was converted to visual studio 2010, but the target framework version is 3.5 and the mindfusion toolbox is not generated, so how can i solve my problem??
Thanks Cheesy
Re: Visual Studio 2010 .net target 3.5
Reply #1 - Dec 13th, 2010 at 4:05pm
Doesn't Toolbox Installer create a tab if you navigate to the .NET 3.5 folder but change the target VS version to VS2010?
Anyway you can add the assemblies manually: right-click the toolbox, select Add Tab, enter name, right-click the new tab, select Choose Items, click Browse, navigate to the .NET 3.5 assemblies folder (VS2008 (.NET 3.5)) and select the ones you need.
isilva
Reply #2 - Dec 13th, 2010 at 4:43pm
Hi, thanks for the quick response!  Wink
I tried this two solutions, but any works, if i check "see all" option in vs the mindfusion toolbox is there, but disabled. Sad
Thanks Wink
Reply #3 - Dec 13th, 2010 at 6:53pm
Try to delete the mindfusion key under this registry key if there's one
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\.NETFramework\v4.0.30319\Assem
blyFoldersEx
then delete the tab with disabled items from the toolbox if it's still there, and add the items manually again.
isilva
Reply #4 - Dec 13th, 2010 at 7:20pm
Thanks a lot Stoyan. Works perfectly!  Wink
