Normal Topic Visio Integration (Read 2472 times)
steve
Visio Integration
Dec 21st, 2010 at 8:26am
We are using the Silverlight diagramming tool and creating Visio type drawing.
What support is there to import a Visio file into the Silverlight tool and then also to export from Silverlight to a Visio file?
Re: Visio Integration
Reply #1 - Dec 21st, 2010 at 11:44am
There isn't any support for this in the Silverlight control. You could try using the VisioExporter and Importer classes from the ASP.NET version.
steve
Reply #2 - Dec 21st, 2010 at 12:11pm
Ok, that sounds feasible. Would I be able to just save the diagram from the silverlight version and open it using the .net version (and the other way around)?
Steve
Reply #3 - Dec 21st, 2010 at 12:32pm
Yes, with some limitations:
1. The .NET version does not support WpfPoint as measure unit, so you might have to temporarily change it to Point before saving the diagram in Silverlight.
2. Export will work only for ShapeNodes. If you are using custom nodes, you will have to convert them to ShapeNodes before exporting.
