Normal Topic Timetable resize and dragging (Read 3331 times)
lelio
Dec 28th, 2010 at 11:27am
Hello people,
I'm evaluating your WPF control, but there are some things I'm unable to do when I show the Timetable view:
a) what's the way to disable the feature that makes appointments draggable (ie: that allows the user to change Appointment time)?
b) is there a way to prevent the user the chance to resize (ie: change the duration) of an Appointment?
c) showing appointments owned by different Contacts, what's the way to allow an appointment to be dragged from a Contact to another one? By default you can drag only within original Contact columns, but your demo does it.
Thank you in advance.
Bye,
Lelio
Re: Timetable resize and dragging
Reply #1 - Dec 28th, 2010 at 11:39am
1, 2) You can set the AllowMove, AllowResizeStart and AllowResizeEnd properties of individual items to false. Alternatively, you can handle the Calendar.ItemModifying event and set Confirm to false.
3) You need to press and hold the key specified by the ItemChangeReferenceKey property, ALT by default.
Let me know if this helps.
lelio
Reply #2 - Dec 28th, 2010 at 11:56am
Dear Meppy,
perfect, thank you.
Bye,
Lelio
