Hot Topic (More than 10 Replies) Zoom function (Read 6525 times)
lead8209
Zoom function
Jan 10th, 2011 at 4:00pm
Hi, i'm trying to write some functions to allow user to create a box that is used in diag_view.FitToRect(zoom_box).
But for some reasons my box doesn't follow exactly the mouse cursor ...
Does someone could help please ?
there is the code :
First we save the first clic emplacement :
	   private void diag_view_MouseDown(object sender, MouseEventArgs e) // initialise le coin suppérieur gauche du rectangle
		if (e.Button == MouseButtons.Left && !isMenuClic)
		    start_screen_position = Control.MousePosition;
		    start_diag_position = diag_view.PointToClient(start_screen_position);
		    if (debug)
			  fd.start_px.Text = start_diag_position.X.ToString();
			  fd.start_py.Text = start_diag_position.Y.ToString();
Secondly the mouse mouse event permits to create the zoom_box
  private void diag_view_MouseMove(object sender, MouseEventArgs e) //dessine un rectangle transparent
     if (zoom_node != null)
   diag_component.Nodes.Remove(zoom_node);
     if ((e.Button == System.Windows.Forms.MouseButtons.Left) && (!isMenuClic))
    PointF current_diag_position = diag_view.PointToClient(Control.MousePosition);
    float width = 0; float height = 0;
    if (current_diag_position.X > start_diag_position.X)
  if (current_diag_position.Y > start_diag_position.Y)
width = current_diag_position.X - start_diag_position.X;
height = current_diag_position.Y - start_diag_position.Y;
if (debug)
    fd.dtp.Text = diagToPixel.ToString();
RectangleF zoom_box = new RectangleF();
zoom_box.Width = width/diagToPixel;
zoom_box.Height = height/diagToPixel;
zoom_box.X = start_diag_position.X / diagToPixel + diag_view.ScrollX;
zoom_box.Y = start_diag_position.Y / diagToPixel + diag_view.ScrollY;
zoom_node = diag_component.Factory.CreateShapeNode(zoom_box);
zoom_node.Shape = Shapes.Rectangle;
zoom_node.Pen = new Pen(Color.LightGray, 0);
zoom_node.Brush = new SolidBrush(Color.Transparent);
zoom_node.Expandable = false;
zoom_node.Text = "Sélectionnez la zone de zoom";
if (debug)
    fd.box_x.Text = zoom_box.X.ToString();
    fd.box_y.Text = zoom_box.Y.ToString();
    fd.box_w.Text = zoom_box.Width.ToString();
    fd.box_h.Text = zoom_box.Height.ToString();
    fd.node_x.Text = zoom_node.Bounds.X.ToString();
    fd.node_y.Text = zoom_node.Bounds.Y.ToString();
    fd.node_w.Text = zoom_node.Bounds.Width.ToString();
    fd.node_h.Text = zoom_node.Bounds.Height.ToString();
if (debug)
    fd.tb_current_mp_x.Text = diag_view.PointToClient(Control.MousePosition).X.ToString();
    fd.tb_current_mp_y.Text = diag_view.PointToClient(Control.MousePosition).Y.ToString();
Thirdly the mouse up event does zoom
 public void ApplyDiagToPixel(bool zoom)
     RectangleF visibleRegion = diag_view.ClientToDoc(diag_view.ClientRectangle);
     float visible_Width = visibleRegion.Width;
     float visible_Height = visibleRegion.Height;
     if (debug)
   fd.visible_diag_h.Text = visible_Height.ToString();
   fd.visible_diag_w.Text = visible_Width.ToString();
     RectangleF fullRegion = diag_view.Bounds;
     if (debug)
   fd.full_diag_h.Text = fullRegion.Height.ToString();
   fd.full_diag_w.Text = fullRegion.Width.ToString();
     float facteur_X = visible_Width / fullRegion.Width;
     float facteur_Y = visible_Height / fullRegion.Height;
     float scale_factor;
     if (facteur_X > facteur_Y)
   scale_factor = facteur_X;
     else
   scale_factor = facteur_Y;
     if (zoom)
   diagToPixel = diagToPixel / scale_factor;
     else
   diagToPixel = diagToPixel * scale_factor;
    if(debug)
lead8209
Re: Zoom function
Reply #1 - Jan 10th, 2011 at 4:11pm
Finally every time the zoomFactor changes we vompute the "diagtopixel" variable.
	 private void diag_view_ZoomFactorChanged(object sender, EventArgs e)
	     bool zoom;
	     if (save_zoomFactor > diag_view.ZoomFactor)
		   zoom = false;
	     else
		   zoom = true;
	     save_zoomFactor = diag_view.ZoomFactor;
	     ApplyDiagToPixel(zoom);
	     if (debug)
	     if (debug)
	     float scale_factor;
	     else
	     if (zoom)
	     else
	    if(debug)
Re: Zoom function
Reply #2 - Jan 10th, 2011 at 4:24pm
I can't see ClientToDoc being called to get the diagram coordinates of the mouse pointer, so I suppose you are using the view-relative pixel coordinates as values of the zoom-node Bounds.
You can see an alternative way to implement a zoom tool here:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=129079283...
You can find several other methods to do the same if you search the forum for ZoomToRect.
lead8209
Re: Zoom function
Reply #3 - Jan 11th, 2011 at 7:37am
Thanks for this example ... I solved my problem !
One more question; Is it possible to customise  the zoom rectangle by using ZoomTool class ?
Re: Zoom function
Reply #4 - Jan 11th, 2011 at 8:29am
ZoomTool uses the Selection object to display a zoom rectangle, so you could customize it through the Pen and Brush properties of diagram.Selection. If you need to show additional graphics, you could custom-draw them from a DrawForeground handler, or use a temporary node as a zoom rect instead of Selection.
lead8209
Re: Zoom function
Reply #5 - Jan 11th, 2011 at 9:05am
public override InteractionState StartDraw(PointF point)
allow to customise the box.
Thanks again.
lead8209
Re: Zoom function
Reply #6 - Jan 11th, 2011 at 9:26am
hmmm ... any way to custome text of rectangle ?
i tryed to cast it to ShapeNode but it's not possible...
i just would the same thing :
zoom_node = diag_component.Factory.CreateShapeNode(num_box);
you told me about a tempoary node but how to cast it and where ?
i tryed DrawForeground handler without sucess...
Re: Zoom function
Reply #7 - Jan 11th, 2011 at 1:22pm
Try this as DrawForeground implementation:
private void diagram_DrawForeground(object sender, DiagramEventArgs e)
	if (diagramView.CustomBehavior is ZoomTool &&
		diagram.Interaction != null)
		e.Graphics.DrawString("Sélectionnez la zone de zoom",
			new Font("Arial", 12 * 100 / diagramView.ZoomFactor),
			Brushes.Black, diagram.Selection.Bounds);
but also add the following to ZoomTool, or otherwise the draw event will be raised just once upon Mousedown:
protected override void OnMouseMove(Point mousePosition)
	base.OnMouseMove(mousePosition);
	DiagramView.RecreateCacheImage();
lead8209
Re: Zoom function
Reply #8 - Jan 11th, 2011 at 2:10pm
Thanks it works !
The following picture shows you what i wish exactly. could you help me ?
I just would like to color the background of my box in gray transparent and recenter my text.
Re: Zoom function
Reply #9 - Jan 11th, 2011 at 2:51pm
Use the DrawString overload that takes a StringFormat argument, and pass a StringFormat instance whose Alignment and LineAlignment members are set to Center.
Regarding the box background, set Selection.Brush to a SolidBrush instance with its Color set to transparent gray.
lead8209
Re: Zoom function
Reply #10 - Jan 11th, 2011 at 3:05pm
how do you do the transparency effect ? I only have Color.Gray ...
Re: Zoom function
Reply #11 - Jan 11th, 2011 at 3:38pm
For example: Color.FromArgb(100, Color.Gray);
lead8209
Re: Zoom function
Reply #12 - Jan 12th, 2011 at 7:17am
Thanks i didn't know that ...
I've got one more problem. I implemented a function mouse_wheel :
if (e.Delta > 0)
if (diag_view.ScrollY >= 0)
diag_view.ScrollY += -5;
else
diag_view.ScrollY += +5;
"if (diag_view.ScrollY >= 0)" permits to stop wheeling on the begining but no way to stop wheeling at the end of the diagram ...
I looked at the FAQ but the attribute .DocExtents is unknown..
void diagramView_MouseWheel(object sender,     MouseEventArgs args)
diagramView fcSender = sender as diagramView;
float newScrollY = fcSender.ScrollY - args.Delta / 50;
if (newScrollY > fcSender.DocExtents.Top)
fcSender.ScrollY = newScrollY;
Re: Zoom function
Reply #13 - Jan 12th, 2011 at 7:50am
It seems that's from an old version. Replace DocExtents with Diagram.Bounds.
lead8209
Re: Zoom function
Reply #14 - Jan 12th, 2011 at 8:39am
Thanks for all...
