Normal Topic TableNode (Read 1699 times)
Advin
TableNode
Jan 15th, 2011 at 11:23am
I need to add shapeNode into table column in top ,
i.e. if i hav table of two row and five column then i want two nodes in second roe and first column and attach these nodes to node of another column is  it possible if yes then how i tried but i m unable to add shapenode into table row or column.
Re: TableNode
Reply #1 - Jan 17th, 2011 at 7:36am
Table cells cannot contain other nodes. You could implement something similar by placing a node at the cell location, found by getCellRect(), and then call node.attachTo(table) to make the node move together with the table.
