Normal Topic GetItemAt when diagram is zoomed (Read 2475 times)
dolfandon
Mar 1st, 2011 at 9:31pm
I seem to be having an issue getting the object that is clicked on when the diagram is zoomed. This is to pop up a context menu and select the item under the mouse when a user right clicks in the diagram. The following code works fine when not zoomed but does not work if the zoom factor is set to anything other than 100. Is this correct or is there another way?
[code] Double xPos = ((pastePoint.X + xScroll) * (currentDiagram.ZoomFactor / 100)) - xDiagOffset;
Double yPos = ((pastePoint.Y + yScroll) * (currentDiagram.ZoomFactor / 100)) - yDiagOffset;
Point checkPoint = new Point(xPos, yPos);
DiagramItem clickedItem = currentDiagram.GetItemAt(checkPoint, false, true);[/code]
TIA
Don
Re: GetItemAt when diagram is zoomed
Reply #1 - Mar 1st, 2011 at 10:33pm
If you have the pastePoint value relative to some Silverlight element, call element.TransformToVisual(diagram.DocumentPlane).Transform(pastePoint) to get the respective diagram coordinates.
dolfandon
Reply #2 - Mar 2nd, 2011 at 2:09pm
Can I call this on the diagram? The point I have is relative to the Silverlight application and not the diagram.
Reply #3 - Mar 2nd, 2011 at 2:33pm
Try calling it on the Application.Current.RootVisual object.
dolfandon
Reply #4 - Mar 3rd, 2011 at 8:50pm
Thanks Stoyo. That does work. Smiley
