We have released version 2.0.1 of DiagramLite. It adds several customer-requested features and small improvements:
Create HTML image mapsHtmlBuilder generates an HTML image map whose <area> elements correspond to the items shown in an exported diagram image. The CreateImageMap method generates a full <map> tag, including its <area> elements. CreateUseMapAttr method creates the code to reference a map from within an <img> tag. The HyperLink and ToolTip properties of items are set as values of the href and alt attributes of the corresponding area elements.
Miscellaneous~ The DelKeyAction property specifies how the diagram should respond to the user pressing the Del key.
~ LinkDeleting and NodeDeleting validation events added.
~ The Id property added to DiagramItem allows assigning custom identifiers to items. It can also be used to just store additional custom data similarly to Tag.
~ Call FindLinkById and FindNodeById to find items by their Id.
~ The ValidateAnchorPoint event allows custom selection of anchor points.
~ Node size constraints can be set through the MinWidth, MinHeight, MaxWidth and MaxHeight members of NodeConstraints.
~ UBendMaxLen property added to QuickRouter.
~ The Ruler.InchDivisions property specifies how many minor divisions to display when Unit is set to Inch.
~ Change and Toggle methods added to the Selection class.
~ The ReassignAnchorPoints method of links selects new anchor points based on the current position of the related nodes.
clients area on our site.
https://www.mindfusion.eu/DiagramLiteTrial.zip
