Normal Topic Setting report page size dynamically (Read 10529 times)
Vikas Kumar
Mar 30th, 2011 at 8:06am
Hi Meppy
I need your help to set the width of report page dynamically based on screen resolution. My report is displayed inside a report window control and i want its size to be same as of report window. My present screen resolution(1600 by 900)
My report is inside the reportwindow.xaml control.
The report control fits itself according to screen resolution but not the report inside and so there comes a gap on the right side.
<Grid x:Name="LayoutRoot">
<Border CornerRadius="5" BorderBrush="#FF28607C" BorderThickness="1">
<Border.Background>
<LinearGradientBrush EndPoint="0.966,0.479" StartPoint="0.002,0.488">
<GradientStop Color="#FF65B1F0"/>
<GradientStop Color="#FFACE8F0" Offset="1"/>
</LinearGradientBrush>
</Border.Background>
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="26"/>
<RowDefinition Height="22*"/>
                    <RowDefinition Height="423*" />
                </Grid.RowDefinitions>
<Border x:Name="Header" Grid.Row="0" CornerRadius="4,4,0,0">
<Border.Background>
<LinearGradientBrush EndPoint="0.17,0.033" StartPoint="0.17,1.032">
<GradientStop Color="#FF134C6C" Offset="0"/>
<GradientStop Color="#FF2A627E" Offset="1"/>
<TextBlock HorizontalAlignment="Left" x:Name="Title" TextWrapping="Wrap" Text="RESULTS: MAGAZINES Plan 1" VerticalAlignment="Center" Style="{StaticResource HeadingReport}" Margin="3,0,0,0" FontFamily="AvantGarde Bk BT" Foreground="White"/>
</Border>
<Border Background="White" Grid.Row="1" CornerRadius="0,0,3,3" Margin="3" BorderBrush="#FF1F4F6B" BorderThickness="1" Grid.RowSpan="2"></Border>
                <report:ReportViewer Name="reportViewer" Grid.Row="1"  Grid.RowSpan="2" Margin="5" PageMargins="0" Style="{StaticResource ReportViewerStyle1}" />
            </Grid>
</Border>
</Grid>
I have a report handler class where I have tried to set the report viewer size.
 if (report != null)
                if (_prvm != null)
                    report.DataContext = _prvm;
                report.QueryDetails += new EventHandler<QueryDetailsEventArgs>(report_QueryDetails);
                report.Run();
                if (_reportControl != null)
                    _reportControl.reportViewer.PageSize = new Size(_reportControl.ActualWidth, _reportControl.reportViewer.PageSize.Height);
                    //foreach (var page in report.Pages)
                    //    page.Size = new Dimension(_reportControl.ActualWidth, _reportControl.ActualHeight);
                    _reportControl.reportViewer.Document = report;
But when the first time the report is loaded it doest change the page size and takes the default value. On consecutive calls the size is changed.
Please help me solve this issue.
Regards
Vikas
Vikas Kumar
Re: Setting report page size dynamically
Reply #1 - Mar 30th, 2011 at 8:27am
Hi Meppy
I just found one solution by setting the size in report_prerender event.
private void report_Prerender(object sender, PrerenderEventArgs e)
Is there any better way to do this.
Regards
Vikas
Reply #2 - Mar 30th, 2011 at 8:57am
Setting the size in the Prerender event is not a really good choice since this event is invoked multiple times for items in the report. Not to mention that setting the ReportViewer.PageSize itself causes a rendering of the report. The most natural place to put this code is in the SizeChanged event of the ReportViewer or its container - _reportControl.
I am trying this and it works as expected. Where were you calling this code originally?
Reply #3 - Mar 30th, 2011 at 9:10am
Additional note: It appears that selecting a new document in the ReportViewer causes the previously set PageSize to be discarded. Try reversing the assignment order by first setting Document, then setting PageSize.
Vikas Kumar
Reply #4 - Apr 5th, 2011 at 11:28am
Hi Meppy,
Sorry for the late reply. I was busy with another work so couldn't get time to reply earlier.
Thanks for the suggestion. I tried changing the page size in both reporttcontrol and report viewer size changed events but it didn't work. But as u suggested later to do the page size change after assigning the report to the document . I tried that and it worked.
                    report.Prerender += new EventHandler<PrerenderEventArgs>(report_Prerender);
Thanks again!!
Regards
Vikas
