Normal Topic Inline Editing: newline with alt + enter (Read 4468 times)
Freizeitsoldat
Apr 19th, 2011 at 5:33pm
Hi Stoyo,
i would like to get a new line ("\n") while im pressing alt + enter during inline editing.
I tried to modify the key handlers in the beginEdit function, but inplaceTextArea.append("\n"); didnīt work.
Do you have an idea?
Thank you very much,
Alex
Re: Inline Editing: newline with alt + enter
Reply #1 - Apr 20th, 2011 at 6:10am
Hi Alex,
Handle enterInplaceEditMode and call e.getEditControl().addKeyListener() to add this keyTyped handler:
public void keyTyped(KeyEvent e)
	if ((e.getModifiers() & KeyEvent.ALT_MASK) != 0 && e.getKeyChar() == '\n')
		JTextArea textControl = (JTextArea)e.getComponent();
		textControl.insert("\n", textControl.getCaretPosition());
Freizeitsoldat
Reply #2 - Apr 20th, 2011 at 7:52am
Hi Stoyo,
i donīt exactly understand where i have to implement the keyTyped handler.
Perhaps i forgot to tell you, that iīm using jdiagram as an applet and i use jscript for interaction.
Alex
Reply #3 - Apr 20th, 2011 at 8:14am
Tough luck, you can't implement a Java listener from JavaScript AFAIK. You could instead do this from your own applet that inherits from DiagramApplet:
diagram.addDiagramListener(new DiagramAdapter() {
	public void enterInplaceEditMode(InPlaceEditEvent e)
		e.getEditControl().addKeyListener(new KeyAdapter() {
Or otherwise set InplaceEditAcceptOnEnter to false and the user will be able to use the Enter key for new lines, and end the edit operation with a click outside the text control.
Freizeitsoldat
Reply #4 - Apr 20th, 2011 at 8:33am
Hi Stoyo,
thank you for the answers.
I donīt know if itīs clear what i would like to implement:
I donīt want to change anything from javascript. I would like to add a keylistener directly in the java applet. I hoped to solve this within beginEdit() in the DiagramView class.
I donīt really understand what the addKeyListener function within beginEdit() does affect at all?
Thank you,
Alex
Reply #5 - Apr 20th, 2011 at 9:42am
The sample code above is what you need then. When you call beginEdit(), that should raise the enterInplaceEditMode event, which you can handle as shown above. That's the only way to get access to the JTextArea used for inplace editing.
Reply #6 - Apr 20th, 2011 at 9:56am
If you mean you have the source code and are directly modifying the beginEdit method, then copy the keyTyped function to the block after this line -
inplaceTextArea.addKeyListener(new KeyAdapter(){
Freizeitsoldat
Reply #7 - Apr 21st, 2011 at 12:11pm
Ahhhhg...
i did it exactly as you recommended before i asked you here in the forum...
It didnīt work because the jar builder didnīt work. That was the reason that i had no effect in the jdiagram.jar.
Thanks!
