I have a flowchart (tree) where some nodes are expandable. I two problems that are easier to explain using pictures. I have the following diagram:
You can see that I have the nodes 3 and 3.1.1 are expandable. The numbers are nodes that are grouped with their nearest node. When I collaplse 3.1.1, I get the picture below. The issue here is that the number 3.1.1 disappears, even though the node is still visible. I dont understand why the number disappears, but the node is still there, even when I have grouped them together.
The major issue is what happens when I collapse 3, and then expand it again. The picture below represents what happens. You can see that I can't even see 3.1.1, even though it still exists in the diagram.
What am I doing wrong? Here is the code I use to create the green nodes, and create the label for the numbers:
function addPlanToNode(parentNode) {
var node = diagram.getFactory().createShapeNode(50, 50, nodeMinWidth, nodeMinHeight);
node.setTag(planTag);
node.setBrush(script.createSolidBrush(170, 230, 170));
node.setId(diagram.getTag());
node.setExpandable(true);
diagram.getFactory().createDiagramLink(parentNode, node);
return node;
function addBoxNumberLabel(node) {
var label = diagram.getFactory().createShapeNode(
node.getBounds().getX(),
node.getBounds().getY() - 4,
node.getBounds().getWidth(),
4);
label.setTransparent(true);
label.setIgnoreLayout(true);
label.setLocked(true);
label.setTag('number');
var format = script.createTextFormat(0,0,false,false);
label.setTextFormat(format);
var group = node.getSubordinateGroup();
if (group == null) {
group = diagram.getFactory().createGroup(node);
group.setAutoDeleteItems(true);
group.setExpandable(true);
group.attachToCorner(label, 0);
return label;
