Normal Topic Align Node Centers (Read 2098 times)
jlspublic
Align Node Centers
Sep 15th, 2011 at 1:45pm
The AlignToGrid property can be used to align the top/left sides of diagram nodes. Is there a convenient way to get the centers aligned instead of the edges?
-JLS
Re: Align Node Centers
Reply #1 - Sep 15th, 2011 at 2:02pm
At this time you can do that from the NodeCreated or NodeModified event handlers. Call node.GetCenter(), pass the point to the Diagram.AlignPointToGrid method, and offset the node with the difference between the two points.
Btw. the version we are now releasing adds Visual Studio -like alignment guides that can be used to align nodes by their centers. You can try the beta build here, but we are releasing the official version today or tomorrow anyway:
https://mindfusion.eu/_beta/wpfdiag_alignmultisel.zip
jlspublic
Reply #2 - Sep 15th, 2011 at 6:23pm
Thanks, your suggestion worked great. I'm including my code here in case someone else wants to do the same thing.
''' <summary>
''' Snap center point of node to grid instead of top left corner.
''' </summary>
''' <param name="Target"></param>
''' <remarks>
''' This makes rows/columns of nodes look better if they are different sizes.
''' </remarks>
Private Sub AlignCenter(ByVal Target As DiagramNode)
Dim CenterPoint As Point = Target.GetCenter
Dim NearestGridPoint As Point = diaSchematic.AlignPointToGrid(CenterPoint)
Dim CurrentLocation As Point = Target.Bounds.TopLeft
Target.Move(CurrentLocation.X + (NearestGridPoint.X - CenterPoint.X), CurrentLocation.Y + (NearestGridPoint.Y - CenterPoint.Y))
End Sub
