Normal Topic How enable unlimited undo? (Read 1986 times)
PDM.
Senior Member
Oct 5th, 2011 at 11:07am
I see my project only have 10 levels of undo or redo?
How can set to unlimited or increase that value?
Is possible?
Best regards.
Re: How enable unlimited undo?
Reply #1 - Oct 5th, 2011 at 11:12am
Hi Pablo,
Set a large UndoManager.History.Capacity value.
PDM.
Senior Member
Reply #2 - Oct 5th, 2011 at 11:47am
Thankyou Stoyan!
Exist some high resource usage like memo usage asociated to higher values?
Best regards.
Reply #3 - Oct 5th, 2011 at 12:52pm
I wouldn't set it to more than a few thousands. The control creates a record containing saved property values, position, relations etc. for each action and that might add up to lots of RAM usage if the application runs for a long time. And the user probably wouldn't like to undo more than a few commands anyway; it might be better to implement some sort of auto-save / revert functionality in the application if you must provide an easy way to undo lots of changes.
« Last Edit: Oct 5th, 2011 at 2:02pm by Stoyo »
