Normal Topic Showstopper error from mindfusion Demo dll (Read 3284 times)
binuvc
Nov 7th, 2011 at 11:43am
When I change the Style property of a Link programmatically to LinkStyle.Cascading, the below Error was caught.
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; InfoPath.2; MS-RTC LM 8; .NET4.0C; .NET4.0E)
Timestamp: Fri, 4 Nov 2011 04:38:22 UTC
Message: Unhandled Error in Silverlight Application
Code: 4004
Category: ManagedRuntimeError
Message: System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.ThrowHelper.ThrowArgumentOutOfRangeException()
at System.Collections.Generic.List`1.get_Item(Int32 index)
at MindFusion.Diagramming.Silverlight.DiagramLink.x4cf22ee19af1c11d(Point x3bd62873fafa6252, InteractionState xab29833053004740)
at MindFusion.Diagramming.Silverlight.DiagramLink.UpdateDrag(InteractionState ist)
at MindFusion.Diagramming.Silverlight.InteractionState.Update(Point currentPoint)
at MindFusion.Diagramming.Silverlight.BehaviorBase.OnMouseMove(MouseEventArgs e)
at MindFusion.Diagramming.Silverlight.Diagram.x2c5d1da1234c3a6a(Object xe0292b9ed559da7d, MouseEventArgs xfbf34718e704c6bc)
at MS.Internal.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName)
Re: Showstopper error from mindfusion Demo dll
Reply #1 - Nov 7th, 2011 at 11:50am
Are you by chance setting Style from a LinkCreating or LinkModifying event handler?
binuvc
Reply #2 - Nov 9th, 2011 at 12:43pm
No, I have my custom XML format containing nodes and links and I am trying to create shape nodes and diagram links through code. I am using the Factory.CreateDiagramLink()
code as below:
DiagramLink newlink = diagramInstance.Factory.CreateDiagramLink(
nodeMap[link.Attribute("BeginActivityUniqueID").Value] as ShapeNode,
Convert.ToInt32(link.Element("UILayout").Element("BeginConnectionPoint").Value)
nodeMap[link.Attribute("EndActivityUniqueID").Value] as ShapeNode,
Convert.ToInt32(link.Element("UILayout").Element("EndConnectionPoint").Value));
newlink.Style = LinkStyle.Cascading
The error occurs when I try to detach the head of the link from the end node.
Reply #3 - Nov 9th, 2011 at 1:16pm
The CreateLink override used to attach links to a specific anchor point does not check if the anchor point actually exists. Are you sure the point indices are smaller than the number of anchor points in nodes' AnchorPattern?
