Normal Topic Frame around a Node if HandlesStyle is set To Dash (Read 2745 times)
Kuzya
Dec 19th, 2011 at 11:00am
How to draw a red frame around a node if HandlesStyle is set To DashFrame ?
Re: Frame around a Node if HandlesStyle is set To
Reply #1 - Dec 19th, 2011 at 11:52am
You could set diagram.ActiveItemHandlesStyle.DashPen to a red pen, if you need this only for the selection frame.
