Normal Topic export diagram into document file (Read 2509 times)
anu
Jan 27th, 2012 at 7:15am
     I have create some diagram using jdiagram. Now i want to export these diagram into document file like in .doc or .pdf file for printing purpose.
Is there any methods with help of them i can copy or draw or write exact diagram on documented file.
Re: export diagram into document file
Reply #1 - Jan 27th, 2012 at 7:36am
You can export to PDF using the PdfExporter class:
http://www.mindfusion.eu/onlinehelp/jdiagram/index.htm?Exporting_the_Diagram.htm
anu
Reply #2 - Jan 27th, 2012 at 8:03am
Thanks sir its working.
