Normal Topic Showing selection handle of node together with anchor pattern (Read 3024 times)
matt.s
Mar 6th, 2012 at 3:39pm
I have a node where the following properties are set;
this.EnabledHandles = AdjustmentHandles.Move;
this.HandlesStyle = HandlesStyle.Invisible;
this.AnchorPattern = AnchorPattern.TopInBottomOut;
This gives me the behaviour that I want in that I can;
1) Move the node around, but cannot resize it
2) Draw links using the little circle at the bottom of the node
However, when I select the node on the diagram there is nothing to indicate visually that it is selected. If I change the properties to;
this.HandlesStyle = HandlesStyle.MoveOnly;
This gives me a shaded border when the node is selected which is great, but unfortunately I can no longer draw links from the node.
Is there anyway to get the effect I am after?
Matt
Re: Showing selection handle of node together with anchor pattern
Reply #1 - Mar 6th, 2012 at 5:27pm
You could set the following and will be able to draw links from MoveOnly nodes that are not selected:
diagram.ModificationStart = ModificationStart.SelectedOnly;
The HatchHandles3 style displays a shade similar to the MoveOnly style + adjustment handles, but will also let you draw links from a selected node. So you could keep the auto-handles modification, hide the disabled resize handles to get the MoveOnly appearance, and still be able to draw links:
diagram.ShowDisabledHandles = false;
e.Node.EnabledHandles = AdjustmentHandles.Move;
e.Node.HandlesStyle = HandlesStyle.HatchHandles3;
e.Node.AnchorPattern = AnchorPattern.TopInBottomOut;
matt.s
Reply #2 - Mar 7th, 2012 at 8:42am
Hi Stoyan,
Thanks for the quick reply.
I have tried that and it is closer to what I want.
1) Can you tell me how to hide the disabled resize handles?
2) To move a node, I have to first select it and then drag - is there any way I can get it to select and drag in one motion like before?
Matt
Reply #3 - Mar 7th, 2012 at 10:50am
Hi Matt,
1) Set diagram.ShowDisabledHandles = false;
2) Set diagram.ModificationStart = ModificationStart.AutoHandles; and use the second code block (you can choose only one of the options shown above, so use the one with HatchHandles3).
matt.s
Reply #4 - Mar 7th, 2012 at 1:32pm
Hi Stoyan,
Yes that has done the trick.
Thanks again!
Matt
