Normal Topic MindFusion.Scheduling for WinForms, version 5.4 (Read 1974 times)
Apr 3rd, 2012 at 3:10pm
We have released version 5.4 of MindFusion.Scheduling for WinForms. The new version includes:
Item Effects
The new Glass and Aero visual effects can be applied to items. To apply an effect, create an instance of one of the effect classes, set up its properties, then add the instance to the Calendar.ItemEffects collection. Currently, there are two effect types available - AeroEffect and GlassEffect. Effects can be added, removed or modified at any time and this will immediately reflect on the calendar. Effects of different types can be applied simultaneously. It is also possible to apply more than one effect of the same type.
Several minor bug fixes when item rendering optimization is enabled.
https://www.mindfusion.eu/PlannerTrial.zip
