Normal Topic How to save/load custom shapes from XML (Read 2242 times)
danilom
Apr 17th, 2012 at 10:44am
Hi Stoyan,
In my diagram I have shape nodes with custom shape.
The shape is created dinamically during node creation based on some user parameters.
An example of these shapes is the following:
Shape = new Shape(new ElementTemplate[]
                                        new LineTemplate(0, 100, 100, 100),
                                        new LineTemplate(100, 100, 100, 0),
                                        new LineTemplate(100, 0, 100 - thickness/width*100, 0),
                                        new LineTemplate(100 - thickness/width*100, 0, 100 - thickness/width*100, 100 - thickness/height*100),
                                        new LineTemplate(100 - thickness/width*100, 100 - thickness/height*100, thickness/width*100, 100 - thickness/height*100),
                                        new LineTemplate(thickness/width*100, 100 - thickness/height*100, thickness/width*100, 0),
                                        new LineTemplate(thickness/width*100, 0, 0, 0),
                                        new LineTemplate(0, 0, 0, 100)
                                FillRule.EvenOdd);
When I save to XML a diagram containing these nodes, the node shape is not saved (and consequently is not loaded in the loadFromXML method).
Is there a way to save custom shapes?
Best Regards,
Danilo
Re: How to save/load custom shapes from XML
Reply #1 - Apr 17th, 2012 at 1:01pm
Hi Danilo,
At this time shapes are saved only by their Id, and any shapes referenced by Id when loading a file must be already defined.
One thing you could do is to assign Ids to the dynamically created shapes, add them to a ShapeLibrary, and use its SaveToXml method to save the shape definitions in a separate file. Then before loading the diagram file, you can call ShapeLibrary.LoadFrom to preload the shapes.
Since the Shape class already has SaveToXml and LoadFromXml methods (used for creating and loading shape libraries), another option is to handle SerializeTag/DeserializeTag events and serialize the shape from there. Anyway with these methods it should be easy to implement built-in support for this in the ShapeNode class - our developer will try to do that in the next few days.
Reply #2 - Apr 24th, 2012 at 8:07am
Hi Danilo,
The version below will save the shape definitions in the diagram's XML file for shapes without an Id. If you specify an Id when defining a shape, only the Id is saved as in the old version, and the control will rely that such shapes already exist when loading a diagram file.
https://mindfusion.eu/_beta/wpfdiag282.zip
