Normal Topic Diagramlinks don't display control points (Read 1278 times)
Amosius
Apr 25th, 2012 at 8:08am
When i load a diagram (own procedure) with nodes and diagram links, i see the control points of the diagram links by placing the mouse of the diagram link. However, some diagram links do not show the control points, but are normally activated. So when i press del key the diagram link will be removed. When i delete the diagram link and create a new one the control points appear normally.
Have you ever heard about this?
Best regards
Amosius
Re: Diagramlinks don't display control points
Reply #1 - Apr 25th, 2012 at 10:31am
I haven't. Are you calling link.UpdateFromPoints after assigning to ControlPoints?
Best regards,
