Normal Topic Hide label contacts (Read 4270 times)
Fernando Castro
Hide label contacts
Apr 28th, 2012 at 3:58am
Hi, when i use this on the client side;
function forma(sender, args) {
var form = args.get_form();
if (form.getType() == 'edit') {
var btnRec = form.getControls()['btnRecurrence'].element;
btnRec.style.display = 'none';
var btnRec2 = form.getControls()['contacts'].element;
btnRec2.style.display = 'none';
I can hide the contacts area but the label CONTACTS remains... how can i hide too? or change the label for translations or write another kind of message?
« Last Edit: Apr 28th, 2012 at 3:32pm by Fernando Castro »
Re: Hide label contacts
Reply #1 - Apr 30th, 2012 at 7:10am
We added support for localization in last release:
http://mindfusion.eu/Forum/YaBB.pl?num=1334157433
You can see it shown below; switch to German or Russian and then create appointment and check its options:
http://mindfusion.co/demos/WebPlanner/Localization/Default.aspx
This should be also included as a sample project in the v2.1 installation.
Fernando Castro
Reply #2 - Apr 30th, 2012 at 6:46pm
Thank you so much. I think this is exactly what i need. I don't have the account on clients area, but i'm going to create one and download the update. Thanks for your fast attention.
Fernando
