Normal Topic Problem with ShapeNode.ResizeToFitText (Read 2741 times)
Vladimir Semenov
May 12th, 2012 at 8:17am
I created simple diagram with several nodes and tried to layout it automaticaly. FlowcharLayout works fine, but resizing nodes to fit text is urgly. None option KeepWidth, KeepHeight works as expected: nodes becomes too narrow. The best results obtained with FitSize.KeepRatio but calling it twice also split words.
What is the best way to automatically resize ShapeNodes to keep complete words inside?
I assigned text via Text property.
Re: Problem with ShapeNode.ResizeToFitText
Reply #1 - May 14th, 2012 at 6:29am
Try setting node.TextFormat.Trimming = StringTrimming.Word;
Vladimir Semenov
Reply #2 - May 15th, 2012 at 9:05am
Thank you. Actually it was my fault: paddings were incorrect and took all height.
Vladimir Semenov
Reply #3 - May 15th, 2012 at 2:30pm
FitSize.KeepRation works. KeepHeight - doesn't. Are there sample how to use FitSize.KeepHeight option? Currently its results are unpredicatble.
Reply #4 - May 15th, 2012 at 5:49pm
ResizeToFitText returns false with KeepHeight if it can't fit the text at all in the current node's height. E.g. if the Text is "line1" + Environment.NewLine + "line2", and the node's height is as big as the font size, it won't be possible to fit both lines without increasing the node's height.
If you need to fit the text as tightly as possible and don't care about maintaining some aspect ratio, you could start with a very large size and call ResizeToFitText twice - once with KeepWidth and next time with KeepHeight.
Vladimir Semenov
Reply #5 - May 16th, 2012 at 7:56am
Wow! It's tricky, but it works!
Thank you very much.
