Normal Topic How to split Link to segments interactively (Read 1209 times)
GoldyWang
May 12th, 2012 at 8:25am
How to split Link to segments interactively.
and
How to do it in code.
Re: How to split Link to segments interactively
Reply #1 - May 13th, 2012 at 5:37pm
If you set AllowSplitLinks = true, you should be able to split a link by selecting it and dragging any point along its segment to insert a new point. This does not work for Bezier links at this time.
Adding new segments can be done by inserting new points into link.ControlPoints. E.g. this divides the first link's segment at the mouse-click position:
private void diagram_LinkDoubleClicked(object sender, MindFusion.Diagramming.LinkEventArgs e)
	e.Link.ControlPoints.Insert(1, e.MousePosition);
	e.Link.UpdateFromPoints(false, true);
You will have to add more points per segment for cascading and Bezier links to keep their shape consistent.
