Normal Topic How to combine several diagramitem (Read 2362 times)
ncepu
May 14th, 2012 at 7:16am
issue:How to combine several diagramitems(diagramnodes and diagramlinks),and I can ResizeRotateCopyPaste the combination like doing them on the shapenode。The function like Microsoft visio’s!
Thank you in advance!
GoldyWang
Re: How to combine several diagramitem
Reply #1 - May 14th, 2012 at 7:28am
Group function can do it, I just do it today:
the code such as: ShapeNode.Attach(...)
this is what i am coding now..
public class TPlace : ShapeNode
public TPlace(Diagram parent)
: base(parent)
this.Shape = CreateShape();
public void AddToken(int count)
TToken tk = new TToken(this.Parent); // ShapeNode derived
TDiagram diagram = (TDiagram)this.Parent;
diagram.AddNode(tk);
tk.AttachTo(this, AttachToNode.TopCenter); // *** the ShapeNode-Place and the ShapeNode-token be 'grouped togather' and can be access as whole interactively.
Tokens.Add(tk);
GoldyWang
Reply #2 - May 14th, 2012 at 7:53am
i try the feature of attached shapes.
wu..
mindfushion can group the nodes and move togather the attached nodes as whole, but, it seems can not scale/magnify them togather.
Reply #3 - May 14th, 2012 at 11:35am
The attached nodes will resize together with the master node if you use the AttachTo(percents) overload.
ncepu
Reply #4 - May 14th, 2012 at 12:18pm
Stoyo,could you introduce it in detail,I am a newble.How to implement the visio‘s combination.
e.g. When I select several shapenodes and links,and click combination menubutton,then these nodes and links combinate together When move or resize it.And when the combination is selected,I click the split menubutton,these nodes and links are  seperated.
Reply #5 - May 15th, 2012 at 6:17am
Child nodes in a group will resize automatically with their master node if you use the AttachTo(node, percents ...) override. Full group rotation is not supported yet; we have just implemented it in WPF (http://mindfusion.eu/Forum/YaBB.pl?num=1336392380) and will port it to WinForms soon.
At this time links can only be the master items in a group. If you need them to scale or rotate with the rest of the group items, you will have to implement this by setting their ControlPoints from the master node's NodeModifying event.
