Normal Topic Strange behavior of FlowChartLayout (Read 1346 times)
Vladimir Semenov
May 16th, 2012 at 9:06am
If FlowChartLayout is used to arrange a diagram with a node connected to 3 child nodes, after arrangement the link to the 2nd child node is pointed to the node center. Other links are connected to the nodes' top edge.
Is there a way to change this behavior? I need in all links tied to the top.
Re: Strange behavior of FlowChartLayout
Reply #1 - May 16th, 2012 at 10:52am
It looks like a bug, our developer will investigate.
Reply #2 - May 18th, 2012 at 6:20am
This version should fix the middle link's placement:
https://mindfusion.eu/_temp/fcl_3links.zip
