Normal Topic Dragging a Node from Diagram to Diagram (Read 1626 times)
ulthien
Jul 18th, 2012 at 10:38am
i think it is difficult to have a correct cursor when the drag of a node leaves the diagram (underway to be dropped in another diagram).
This is due to the WPF freezing the eventing while the drag is on [the events don't fire until mouse button is released IMHO]: i.e. i had difficulties to detect that drag left the viewport in order to set the cursor.
Has anyone found a solution to showing a changed cursor when the dragging (of a node) leaves the diagram?
cheers
Re: Dragging a Node from Diagram to Diagram
Reply #1 - Jul 18th, 2012 at 11:29am
During drag-and-drop operations the cursor is set by Windows depending on the drag result set in DragOver event handlers. If you need to show a custom cursor, I think you are supposed to do that only from the DragDrop.GiveFeedback event.
