Normal Topic Can Chart (Pie) response to Mouse-drag user-interaction? (Read 6793 times)
lyrock
Aug 12th, 2012 at 6:16am
can Pie response to user-interaction like that in the attached pic.
I want to drag the edge (tag) of the pie, in order to change the percentage of each section.
Yan
Re: Can Chart (Pie) response to Mouse-drag user-interaction?
Reply #1 - Aug 13th, 2012 at 6:29am
At this time this is supported only for bar and line charts. Our developer will try to implement it for pie charts in the next few days.
lyrock
Reply #2 - Aug 13th, 2012 at 5:32pm
Thank you, Stoyan.
I tried the bar chart. It works fine.
I came across another question:
I couldn't find any event related to when/after "Mouse Drag" happens.
I want to make some calculations with the new values right after I drag the bar.
Thank you.
Yan
lyrock
Reply #3 - Aug 13th, 2012 at 6:16pm
I found this event MouseCaptureChanged, which works for my purpose.
Reply #4 - Aug 17th, 2012 at 7:42am
This version adds AllowEdit property to PieChart:
https://mindfusion.eu/_beta/edit_chart.zip
When it is enabled, you can edit data values by dragging the radius line between two segments. The control will also raise DataChanged event when the user resizes segments.
