Normal Topic Date format in line chart (Read 3719 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Sep 17th, 2012 at 5:59am
Dear Stoyan,
             i need to display the date in the line chart. my expect format is dd-MM-yy
but i  am receiving format is day MMMM ...
my code is
LineChart1.XAxisSettings.DataFormat = MindFusion.Charting.DataFormat.DateTime;
kindly help
if you want something then go and grab it
Re: Date format in line chart
Reply #1 - Sep 17th, 2012 at 1:00pm
In order to show date time values in custom format, you should do the following:
BarChart1.YAxisSettings.DataFormat = MindFusion.Charting.DataFormat.DateTime;
BarChart1.YAxisSettings.DateTimeFormat = MindFusion.Charting.DateTimeFormat.CustomDateTime;
BarChart1.YAxisSettings.CustomDateTimeFormat = "dd-MM-yy";
