Normal Topic Need to add right click on node (Read 3045 times)
anu
Oct 6th, 2012 at 10:19am
I m using javascript jdiagram I m able to generate click event on node by using following code
function nodeClicked(sender, args)
      var node = args.getNode();
      var chld=getValues(node.getTag());
      alert(chld);
    if(node.getTag()!=null)
        ///code for event handling
now i want to add right click event on node.What change i need to do in it?
Re: Need to add right click on node
Reply #1 - Oct 6th, 2012 at 11:31am
The same event is raised for right clicks too, but you might have to disable the browser's context menu first:
Sys.Application.add_load(function (sender, args)
	var diagram = $create(MindFusion.Diagramming.Diagram,
		null, null, null, $get("diagram"));
	diagram.addEventListener(Events.nodeClicked, onNodeClicked);
	diagram.get_element().oncontextmenu = function () { return false; }
function onNodeClicked(sender, args)
	// handle right-button click
	if (args.getMouseButton() == 2)
anu
Reply #2 - Oct 17th, 2012 at 4:19am
Thanks Its Working
