Normal Topic diagram.ActiveItem (Read 3023 times)
donalmeida
Yay...
diagram.ActiveItem
Oct 22nd, 2012 at 1:52pm
Hi, We upgraded our controls to Silverlight 5 (2.3.0.16737) and this code stopped working. on Key_Down event we trap the delete key event and run this code
  CustomDiagramLink link = currentDiagram.ActiveItem as CustomDiagramLink;
            if (link != null)
                DeleteRoute(link);
            DiagramNode node = currentDiagram.ActiveItem as DiagramNode;
            if (node != null)
                DeleteNode(node);
This used to work before but now diagram.ActiveItem is null. is there a better way to do this?
Don Almeida.
Re: diagram.ActiveItem
Reply #1 - Oct 22nd, 2012 at 2:01pm
The control might be deleting the ActiveItem automatically now. Try setting DelKeyAction=None if you wish to process Del yourself.
donalmeida
Yay...
Reply #2 - Oct 22nd, 2012 at 8:34pm
I tried it Stoyan, but the ActiveElement is still null. it is null even in this event handler. (of course i can get the link from the event args but in this case I was just checking if setting the delkey action helps me or not).
private void diagram_LinkDeleted(object sender, LinkEventArgs e)
            DiagramItem dgi = currentDiagram.ActiveItem;
            if (dgi != null)
                // check B rules
Don Almeida.
Reply #3 - Oct 23rd, 2012 at 6:23am
Diagram.ActiveItem is automatically set to null when the item is deleted, so if you need to know what has been deleted, you will have to check the LinkEventArgs indeed.
In any case, I don't think you can get to the LinkDeleted event if DelKeyAction is set to None and you are not deleting the items yourself in response to Del key, so check your code again: either DelKeyAction is disabled and you manage to delete ActiveItem from the KeyDown handler, or DelKeyAction is enabled and you are getting LinkDeleted raised because of it.
