Normal Topic Deleting a shape in the shape designer (Read 3019 times)
saad
Oct 23rd, 2012 at 3:08pm
All I need is the rounded rectangle and the little graphic.
The graphic never shows.
Re: Deleting a shape in the shape designer
Reply #1 - Oct 23rd, 2012 at 4:49pm
You should be able to delete shape elements by right clicking and selecting Delete from the context menu. Note that the rounded rectangle you have added is considered a decoration and won't be filled. To get round rect as shape outline, starting from the initial four line elements of a new shape, delete three of them, for the remaining one select convert to -> round rect from the context menu, and then resize it accordingly.
saad
Reply #2 - Oct 23rd, 2012 at 4:50pm
Got it, cheers. Smiley
saad
Reply #3 - Oct 23rd, 2012 at 6:57pm
What exactly is the purpose of combine?
Reply #4 - Oct 24th, 2012 at 5:45am
If you click the common point between two line or bezier segments, it will merge them into a single one. I'm not sure if it does anything with round rects.
saad
Reply #5 - Oct 24th, 2012 at 5:51am
Thanks.
